Low pressure water filter
chocobanana
Industrial
Jun 5, 2005
15
Greetings
Does anyone knows where can I find a water filter designed for low pressure with a very closed porosity of 0.2 micron?
I'm looking for these in the form of discs or sheets for long term use. The thickness doesn't matter too much, but 4 to 6 mm would be ideal.
Check with 3M they should have what you are looking for.
That is a reasonable price for the quanity that you are interested in. You are trying to purchase a precision filter.
You option is to purchase the filter media sheets and fabricate your own water filters. This option would probably cost you even more.
I don't understand why you are asking for filters if you already know where you can buy them.
I would think that you are going to have to buy a standard off the shelf product and then customize the product to your application. Your volume is not sufficient enough to induce a manufacturer to produce one for you.
