I am working on a product that is currently using a normally open normally closed [edited] reed switch that when a magnetic field is present turns on off [edited] a small LED. I was told other types of sensors like a hall effect sensor was looked into but the longest battery life that could be expected was 2 months with a 2032 button cell battery. The primary reason for wanting to get away from a reed switch is to be able to adjust the trigger point (the distance a magnet has to be to turn on an LED).
Does anyone have any experience with any types of magnetic field proximity sensor that could have circuitry that would allow for adjustment of the trigger point by something like a potentiometer and have a battery life > 2 months (hopefully a year or more) assumingthe it is not triggered turning on an LED a magnetic field is present and the LED is turned off [edited].
Thanks in advance.
Thanks in advance.
