arsef is right...its ugly and will cause drainage problems, but lowering the pump may be the best answer
During the preliminary layout design phase of the facility, the very low NPSHa should have been evaluated.....why was this not considered earlier ?
You can find "low NPSHa" pumps advertised.....but as I recall, the NPSH that they require is about 5 feet....
All NPSHr quoted by pump vendors are in terms of "feet of water"....if your process liquid has a significantly different density that water, you must adjust
My thoughts only.....
MJC
