Is it an MTS or Instron type servo-hydraulic fatigue machine? 3000 psi hydraulic pressure? Typically you would purchase a Hydraulic Service Manifold (HSM) and install close to the testing machine. HSMs come with HP and LP accumulators, filters, on/off valve, check valves etc. All you need to do then is install hydraulic lines to the HSM from the pump and from the HSM to the testing machine.
