metboss
Petroleum
- Sep 12, 2012
- 153
Good day !
We placed an order for some equipment to be used in a high temperature/high pressure well with H2S exposure, so the material has to be NACE MR0175 compliant. The required material grade is API 5CT “T-95”low alloy steel whereas manufacturer has supplied equipment fabricated out of C95/4140 grade Quenched/Tempered Steel. The main reason of rejection is deviation in grade & SSCC test (NACE TM-0177) which was not carried out by manufacturer as required by API 5CT for T-95 garde. Upon rejection, manufacturer has justified with following response:
“As per NACE MR0175 spec paragraph A.3 which states that any Cr-Mo Low ally steel in quenched and tempered condition is accepted for use throughout SSC Region 2.
C95 or 4140 Q&T should be suitable for sour service in any region if the service temperature when exposed to sour fluids is continually 150°F or above, as per NACE Table A.3”.
My question is that without doing actual SSCC testing as per NACE TM-0177, how they can justify the above. If so, then why API 5CT categorized various grades (L 80, T-95, C95…etc)? Even without doing SSCC test, one can accept C95/4140 grade in lieu of T-95 ??
