(1) I'd love to find a comprehensive list of loss coefficients for liquid flow. Each table I find seems to have different K values (discounting the fact that Moody f = 4 x Fanning f) or is missing some fittings. Since the coefficients can be derived empirically or analytically, do standard values even exist? Two tables that appear to be useful are:
pump.net/frictiondata/friclossfittings.htm
At the first website there is a section for 90 Bends, etc.
(2) What is the difference between "90 Bend" and "Pipe Bend?" If it's the angle, why aren't there separate values like in Thrusterman's post in thread378-8478?
(3) If r/d is bend radius / pipe diameter, why would K generally increase with increasing r(/d)? I would think that a rounded corner wouldn't disturb the flow as much as a sharp corner.
(4) How can coefficients be expressed as L_equiv/D, which = K/4f (Moody) or K/f (Fanning)? f here is a standard turbulent friction factor depending on pipe size (second website), but shouldn't this f also depend on the Reynolds number?
(5) Must the pipe lengths upstream and downstream relative to the fitting's location both be >> D to include K? What if I have a 90 deg elbow immediately at a pump outlet? What about back-to-back reducers?
