Losing section :(
  • Thread starter Thread starter KK_designer
  • Start date Start date
K
KK_designer
Guest
What is the best way to do section in assembly model for references steadiness??
I´m using sometime section with "offset" and sometime with plane, but when I change some parts in assembly the section just dissapear or missing references. OK, I´m aware of section with planes if you select plane on modified surface you will lose references, but you can redefine later. Now when I use "offset" section, some time it just practically dissapear. It happens often when I´m trying replace components wich are included in section.
Ty
sorry im on WF4, by the way
I've found the best way to prevent offset sections to be unstable is to create them using references that you want to show in the section. Once you have the section you want, delete all references except for two datums that define your default csys. The section will now be stable, but if you move things, it won't follow.
