K
KK_designer
Guest
What is the best way to do section in assembly model for references steadiness??
I´m using sometime section with "offset" and sometime with plane, but when I change some parts in assembly the section just dissapear or missing references. OK, I´m aware of section with planes if you select plane on modified surface you will lose references, but you can redefine later. Now when I use "offset" section, some time it just practically dissapear. It happens often when I´m trying replace components wich are included in section.
Ty
Ty
