We have a lot of old lifting equipment around and are having compatibility issues with trying to design new hardware for them. In particular, many of our bridge cranes have load blocks with pins to attach lifting devices. Frustratingly, these pin sizes vary between the cranes and many of them are unusually large for the load capacity. So the challenge for trying to design something interchangeable is having to either make custom linkages for each crane or having loose fitting pins. As I expected, the in-house analyst said that the pin should be as tight of a fit as possible (which I know is the optimal situation). However, I know the guys on the floor have been using sub-sized pins for years in these cranes. Of course that doesn’t make it right, but talking with them and some vendors it sounds like this is not unheard of in the lifting industry.
Unfortunately, I am not super familiar with lifting codes/regs and I was wondering if there is an industry standard that addresses pin/lug fits or some alternative sizing method that helps determine if you can use a smaller pin in a larger hole? If we wanted to put, say, a 3 inch pin in a 6 inch hole, is there anything we could check to feel more comfortable with the strength of the assembly other than just gut feel of the lifting crew?
