Looping the root function 1
cjm2176
I want to find and save the root of a function, make a small change to a parameter in the function and find the new root.
I defined the parameter over an interval, but MathCAD's root function doesn't like this (I get a message that says root only works with matrices or scalars), though there are no errors if I define the parameter with only one value.
I also tried using a for loop to evaluate the root, but MathCAD doesn't give either an output or an error, nothing happens.
Is there another way to go about this?
Thanks!
>> Nowhere do you define beta.nd, so why is it a surprise that it's flagged as undefined?
>> Your construct of k.nd is interesting, but not necessary. Do:
i:0,1;10
k.nd[i:i/10
this will create an indexed variable k.nd
Also, you need to define beta.nd somewhere near the top of the sheet.
Then, you do
r0[i:root(f(beta.nd,k.nd[i),beta.nd)
TTFN
FAQ731-376
Thanks! your explanation was very logical, and much easier than creating loops
Since I beta.nd was the argument to my function, I thought it did not have to be defined
It's an argument, yes, but when you call the root function, it needs a starting guess value to start the root finding algorithm.
TTFN
FAQ731-376
