I wish to use VBA to insert a column of random numbers into a spreadsheet using the Data Analysis Add in - Random Number Generator.
My problem is that the macro for the random number generation requires the cell refernce in which to start the column of numbers.
Syntax:
Application.Run "ATPVBAEN.XLA!Random", ActiveSheet.Range(RefCell), 1, 200, 2, 1, 2.83, 0.5
The 'RefCell' is the problem, having assigned 'RefCell' with the required cell designation using the following:
Set RefCell = Worksheets("Sheet3"
.Cells(2, Counter)
The generator will not work using Range (refcell) so can anyone tell me how to get in to work.
In the end I would like the spreadsheet code to loop along the horizontal axis, top row of the spreadsheet filling in columns of rabndom numbers as it goes with code something like this:
Counter = 1
Do Until Counter = 20
.Cells(2, Counter)
Counter = Counter + 1
Loop
so I should end up with 20 seperate columns of random numbers using a loop or something..
Anyone??
Help would be greatly appreciated..
S
Syntax:
Counter = 1
Loop
Anyone??
S
