MaxPlanck
Chemical
- Jan 2, 2006
- 25
Hi experts,
I'm looking for composite which should fulfil following expectations:
- thermal stability (+150°C)
- strength (tensile strength +100Mpa), retain this strength at this high temperature
- retain its shape at this high temperature
Today we use PES, reinforced with 30% glass fibre. We are searching for a material with the same properties. The problem with our present material is the high cost due to the long cycle time (cooling in the mould after injection moulding). It takes almost 20 minutes, according to our supplier, to manufacture one band with cogs on the outside. This band is used to drive a rotor, which is situated in the band, the band is around this rotor.
I hope my explanation is understandable enough.
Best regards and thanks in advance,
Max
Max
