Looking for macro to traverse configurations 2
dogarila
CA
I am looking for a macro to go from configuration to configuration and save a snapshot (jpeg) of each one. Is anyone aware of something like this?
SolidWorks API Help
Iterate Through All Configurations Example (VB6)
This example shows how to iterate through all of the configurations in a document and forcibly rebuild each one. It assumed that you have an active document.
Code:
' Forcibly rebuild each configuration
Option Explicit
Sub main()
    Dim swApp                   As SldWorks.SldWorks
    Dim swModel                 As SldWorks.ModelDoc2
    Dim vConfNameArr            As Variant
    Dim sConfigName             As String
    Dim nStart                  As Single
    Dim i                       As Long
    Dim bShowConfig             As Boolean
    Dim bRebuild                As Boolean
    Dim bRet                    As Boolean
    Set swApp = CreateObject("SldWorks.Application")
    Set swModel = swApp.ActiveDoc
    Debug.Print "File = " + swModel.GetPathName
    vConfNameArr = swModel.GetConfigurationNames
    For i = 0 To UBound(vConfNameArr)
        sConfigName = vConfNameArr(i)
        bShowConfig = swModel.ShowConfiguration2(sConfigName)
        nStart = Timer
        bRebuild = swModel.ForceRebuild3(False)
        Debug.Print "  Config       = " & sConfigName
        Debug.Print "    ShowConfig = " & bShowConfig
        Debug.Print "    Rebuild    = " & bRebuild
        Debug.Print "    Time       = " & Timer - nStart & " s"
    Next i
End Sub
That may give you a start.
I'm sure someone posted a complete macro a long time ago, but have had no luck finding it yet.
[cheers]
Thanks, CBL.
Actualy I've already found that example and modified it o my needs.
So do you now have a fully working macro?
Can you post for future reference? This comes up occasionally.
[cheers]
Here you go:
Code:
' Save each configuration as JPG
' It assumes a model is open and active.
Option Explicit
Sub main()
    Dim sFileName               As String
    Dim sPathName               As String
    Dim i                       As Long
    Dim bRet                    As Boolean
    Dim longstatus              As Long
    Set swApp = Application.SldWorks
    sPathName = "G:\Working\Design\JPG\"  'change sPathName as per your needs
        nStart = Timer
        'bRebuild = swModel.ForceRebuild3(False) 'Forcing the rebuild will slow down the process
        sFileName = sPathName & "A" & sConfigName & ".JPG" 'Use A, B, C, ... to save in different views
        longstatus = swModel.SaveAs3(sFileName, 0, 0)
    Next i
End Sub
