davidd31415
I would like to track the movement of a part over a 1-2' arc as part of a durability test on components that are moved by motors. The motors turn about 90 degrees and the components travel in 1-2' arcs. The motors are actuated in extreme environments (-40C, 60C/80%RH, salt humidity, dust) for several days or weeks at a time.
I would like to produce graphs showing the speed of the moving component as a function of time so that any speed fluctuations that occur while the motor is running can be realized. Tracking the position with a resolution of an inch or better would be ideal.
Would RFID be useful in this application? I am curious what technology is used in the making of computer-animated films, where sensors are mounted to people and the movement is then reproduced on computer screens. I’ve considered machine vision but expect integrating it in extreme environments will be difficult.
Currently I have a system setup that monitors the extreme positions of the moving components using magnetic sensors and magnets mounted on the moving components. I’ve thought about mounting extra magnetic sensors but am hoping to come up with something better.
Any ideas will be appreciated!
Thanks,
Dave
Thanks,
Dave
