drewbr549
- Aug 16, 2006
- 12
Hi all,
I got such great advice in the "concrete as insulation?" post that I thought I'd see what I could mine out of a general question. My situation is that I'm taking my part-time amp repair business from the kitchen table to a "real" test bench, and am coming up with setup/construction questions that I never thought I'd have.
Here's where I'm at right now: I have a bench, approx. 3 ft high (I've always worked sitting down, but thought that standing might be nice for a change - I may change my mind
), and a shelf above the bench that puts my test equipment at about eye level. The room I'm in is concrete on all sides (see thread248-162816). The suggestions I've had so far for flooring are "thick PVC or similar mat" and linkable floor-panel risers. For an insulated bench (assuming that's the route to go), formica has been suggested. It has also been suggested that I install a 10mA, instantanious trip GFCI (I also have an isolation transformer for any transformer-less stuff I work on, though I don't get much).
If there's a consideration that should be in this list that isn't, or if anyone has ANY other suggestions for setting up a test area, I would greatly appreciate them!
Thanx,
drew
p.s. Oh yea - I mostly work on audio gear ( low voltage stuff, but line voltage is there too, naturally, and the occasional tube amp I get in has some pretty high voltages. I do have a pair of KV gloves, but I'm a clutz with them on. Some people say to at least keep one hand behind yer back for HV work, but I hate doing that, too (and it makes me clumsy, and twice as likely to screw something up. One glove, maybe? comments?
Thanx,
drew
