looking for duocheck valve
Henry07
IT
looking for 3" duo check valve fire safe tested to be used with seawater class 150
anyone can help
tks
Henry
I think you can go to goodwin, they are specialized the wafer check valve.
I would be loathe to use a valve of this type on sea water service without a thorough evaluation of materials and dynamic behaviour.
I have experienced spring & pin failures in sea waater. On one gas platform one half of the disc disappeared. Check out the nuclear regulatory reports of failures of this type of valve. Corrosion can occur in stagnant areas even with super duplex materials.
In desalination plants we specify super duplex annulus type check valves from Noreva or equivalent.
Check out Fluid Transients in Pipeline Systems by ARD Thorley and also Delft laboratories re dynamic behaviour of check valves and how poorly these perform without strong springs. Of course heavy springs increase head loss
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
I am curious why one would use a firesafe valve on seawater.....
