Looking for an alternate to NAVMAT P-9492 (ESS TESTS)
main9
Aerospace
1)Navmat P-9492 (Navy Manufacturing Screening Program, May 1979) provides guidance for conducting thermal and vibration tests to eliminate most latent workmanship defects in avionics electronic equipment. I understand the doucment has been canceled.
2) I would like to know if there is any another (similar) document that is suitable, available and is currently used as a reference in military/commercial applications to conduct ESS tests (thermal/vibration) to eliminate latent workmanship defects.
Thank you.
I don't think you need an alternative. The so-called Willoughby profile is considered a starting point and as Tom Irvine has already pointed out the final screnn is what works best for the product. That is a screen that weeds out defective units without damaging good ones. [sig][/sig]
MIL-HDBK-2164A ESS Process fo Electronic Engineering (for guidance only).
Tri-Service Technical Brief 002-93-08 Environmental Screening.
