I am checking an irig b signal which in this case is modulated with a 1 khz signal. Being as it is amplitude modulated I would expect a solid 1000 cycle rate to show on the frequency counter. When I measure the signal it ranges from 994 hz to 1002 hz, transitioning back and forth at a regualar rate. Is this normal for irig b ? I have never measured it before with a freq. counter, so I am not sure myself. As it is a 100pps signal, are these pulses keeping it from staying a steady 1khz ?
