numberfive
- Mar 18, 2011
- 48
Under the heading "9.7.3 Welded Pipe Tests" NFPA 59A, 2009 Edition states in para. 9.7.3.1 - Longitudinal welded pipe that is subjected to service temperatures of -20 deg. F (-29 deg. C) shall meet one of the following requirements:
1 - It shall have a design pressure of less than two-thirds the mill proof test pressure or subsequent shop or field hydrostatic test pressure.
2 - It shall be subjected to 100 percent radiographic or ultrasonic inspection of the longitudinal or spiral weld.
Question 1 - Is the "mill proof test" refering to the hydrostatic test required by most ASME & ASTM pipe & tube material specifications (ex: SA-312) or is this an additional test performed by the material manufacturer?
Question 2 - Is it acceptable to use longitudinal welded pipe that has had a nondestructive electric test (eddy current not RT or UT) in lieu of a hydrostatic test as allowed in the material specification (ex: SA-312 Type 304/304L) when the pipe will not receive a shop or field hydrostatic test at 1.5 times the design pressure, but rather a pneumatic test at 1.1 times the design pressure per B31.3.
Any input would be greatly appreciated.
Thanks!
Thanks!
