rocfill
Geotechnical
- Nov 11, 2008
- 1
Hi Everyone,
Long time reader, first time poster here. I'm hoping I can tap into the massive amount of experience on this board.
Background:
I'm currently conducting settlement analysis for a shallow foundation (maximum applied pressure of about 50-60 PSI). The foundation will be founded on fill, native sand and gravel and/or bedrock, in descending order. The fill will be a well graded durable rockfill (4" to 8" max particle size) with trace fines produced from a quarry/crushing plant. The fill thickness will be up to 45 feet. The in-tact rock strength of the quarry rock is strong to medium strong. A method spec is in place which would see the rockfill placed in loose lifts of up to 16" and compacted with 8 to 10 of passes with a vibratory roller.
I have a number of papers which research the long term deformation of rockfills used in dam construction. I think this is well documented and I think I understand the mechanisms behind these settlements. However, in my case, I do not have the relatively high in-situ stress commonly associated with some of the dam settlement case studies (no pun intended).
Questions:
Assuming good construction practices, would you be concerned about long term settlement of the rockfill described above? What would you say if the differential settlement criteria was extremely low (<1/4" over 25')? Does anyone have previous experience with the long term performance of a similar fill?
Thanks in advance.
Background:
Questions:
Thanks in advance.
