Long Term Behaviour of Bangkok Clay
sango
Geotechnical
Oct 5, 2002
15
Dear all,
I am doing a finte difference numercial analysis on a lateral loaded piles in Bangkok Clay.
I have carried out undrained analysis (short term stability checking?) that allows built up of excess pore water pressure.
I need to study the long term stability, My questions are as follows:
(1) Despite change in possion ratio(0.4-0.5 for undrained case and 0.3-0.35 for drained case), is there any reduction in Young Modulus of the Clay in drained case (long term)or Effective analysis is essential in Clay?
(2) Mohr-Columb was adopted in my model. Is there any typical values of Bangkok Clay in drain case? I think that effective cohesion become zero and effective friction angle is a small value (<25 degree).
(3) Only Vane Shear tests had been carried out. Is there any empircal correlation between soil parameters drained and undrained cases?
Many Thanks.
Hi sango,
(1) Elastic principles tell us that Edrained will be about 0.77 times E undrained. [Eu=1.5 x Ed /(1+v')]. However, this reduction should not have a significant effect on the result.
(2) Typical drained values for Bangkok marine clays about 0-3kPa and 24 to 27 degrees.
(3) Vanes ok for a reasonable estimate of undrained shear strength. Should use Bjerrum's correction factor. I don't know of any relationship between Su and c'.
Hope this helps.
