I am working in a church building with long span glulam trusses. The trusses span 70' and are 20' o.c. The profile of truss is shaped like the letter A. Pitch is 7:12. The dificult part about this problem is the thrust force. I have to model the truss as pinned-pinned in order to limit lateral deflections. The thrust force comes out to be 57k at each column. The best way I could figure of resolving this is to use large tube steel or wf columns cantilevered up from the footing. I think I could notch the glulam top chord member to make it a bucket connection. Part of it would sit on top of the column for the vertical component, part of it would bear against the inside face of the column to transfer the thrust force through direct bearing. Does anyone see any problems with this connection? I am wondering about stress concentrations in the glulam beam with such large forces.
The footing is going to be montrous to resist the overturning. the lateral thrust at the footing can be resolved with a grade beam or hairpins.
Thanks,
Cody
Thanks,
Cody
