Long Shot? Who knows VAG 1.8t management? 1
BigTank
I'm chasing gremlins and need someone with intimate knowledge of the VW 1.8t boost, ignition, valve (cam) timing control, and fuel management. I can't use VAG-COM until I know where to look (and find someone w/ VAG-COM that I can borrow).
It's a long shot, but I thought this might be a good place to look for expertise.
Fitter, happier, more productive
try TDIclub.com. Naturally, they are diesel fiends, but I expect some would know the gas side as well. Should be able to find someone w/ vag-com.
The vagcom will let you know where to look.
I have all you could ever want to know on the 1.8T also.
Brian,
moon161, I've seen that message board before. I brouse (read: lurk mostly) the vwvortex boards. It just seems that the majority of younger people working on their cars are flying blind, so to speak. That is, the glut of the information out there is generated from 'shadetree' types that are shooting in the dark swapping parts. Most probably don't know what a multimeter is, let alone where to find the values of the temperature sensor resistance for a properly functioning sensor.
BrianGar, I'm looking for boost control logic, specifically. As I'm sure you know, this might include the EGR 'system' and the other ancillary systems that use boost for one thing or another. Of course, the boost control and other systems could be treated completely separately. I'm experiencing occasional erratic boost and slightly fluctuating power, along with an occasional sometimes erratic miss at idle and no CEL. It's all very confusing. Do you have any information available that you could send me related to the above systems?
I would say scan the car first to be honest. I have anything you want, but I dont feel there is need to re-invent the wheel if you already have the plans.
They suffer a lot of common problems that are boost related as you describe. Most common ones are boost leak, n75 valve, failing turbo, low oil pressure, failing coil packs, throttle body misalignment and so on.
Vortex is a great forum, and there is a lot of very smart guys on there. Its often the case though, that the smart guys stay quiet as most things have been answered if you search. Saying that most on there dont know what a multimeter is is just daft.
Get your car scanned - this is why vagcom exists - no guessing, saying that you cant use it until you know where to look makes me think you dont know much about them to be looking in the first place, but I could be wrong.
Brian.
BigTank,
I very much doubt that you will be lucky enough to get your hands on the ME7 EMS Function Frame (Strategy Document) and I wouldn't expect it to mean much to you anyway, not without more background information.
Personally I don't have any experience with your particular vehicle but I have touched upon ME7 EMS.
MS
mattsooty, thanks for the response.
