Can anyone suggest a good aluminum blind rivet, in 3/8 or 1/2 inch diameter that will work over a 2 inch grip length? I am hoping for a nice wide bubble at the back end to limit the local stresses on the surrounding aluminum hole.
Huck makes a 1/2 inch aluminum Magna-Lok, but grip is not long enough and Magna-Lok back ends apply very localized loads to hole edges.
The fastener is required for secondary loads in tension, i.e. they are only being used to stabilize a flat plate that is carrying compression against outward buckling.
Thanks.
tg
Thanks.
tg
