boreholelogger
I have a 2.565km piece of wire-line 4 conductor cable wound onto a winch that is used in the mineral exploration industry. The cable has an 85 ohm/km resistance which means that there is 218 ohms resistance from one end of the cable to the other, (Where the camera will be connected) and 218 ohms return line back to the power supply. I require 30VDC @ 400mA across the camera system which will be connected on to the end of this cable. I have ran a few tests and the camera system's current changes from 320mA to 400mA constantly which means that the voltage across the camera system fluctuates alot to provide constant power. The issue I have is that the system requires 200VDC at one end of the cable to provide 30VDC @ approx 400mA across a 75 ohm resistor (This resistor sort of simulates the camera system). Also the initial voltage supplied to the camera is 200VDC for a short moment which would blow the camera's regulator to smitherines. The camera's regulator can withstand 9 - 48VDC. Does anyone know how to help me OR anyone that can help me with this issue?. Or does anyone know of a 30 - 300VDC regulator that can be mounted on a PCB?. Also maybe someone might have a circuit that has used a transorb or something to minimise the impact upon the camera system on the initial startup.
