Lofting of a boat hull
  • Thread starter Thread starter Berry van Mil
  • Start date Start date
B
Berry van Mil
Guest
Hi people,
I am modeling the hull of a small boat. My method is to divide the hull into two sections and use loft to model the boat. However, I keep getting stuck with the lowest part. Loft isn't working over there for some reason.
I have uploaded the .ipt file. If someone would like to take quick look, I would be helped a lot. Besides, I am not sure if the method I use is an effective way of modeling this hull. If someone has an alternative recommendation, this would be very welcome. (I would like to model a boat like the "Zee marine 26".)
Best regards,
Berry
Ew, I also face same problem with you. It seems noone know the solution -.-
