Loft with a Hole in the Section 2
Tugummi
Does anyone know of a way to create a loft on a set of curves including a hole?
Attached is an image of the curves I'm working with. They are irregular shapes. I've been messing with some of the surface features (mainly loft) for a while and I can't figure out if it's possible to include the hole in a single loft-like operation. Can I select all of the bottom curves as the starting point, then select all of the top curves to be the end point some way? Does a hole basically screw up the boundary conditions and make the solution impossible?
I can loft the outer curve and inner curve separately then subtract the hole, but I'm looking for a more concise solution.
Thanks!
 http://files.engineering.com/getfile.aspx?folder=51e07129-ba09-4fa7-8524-77447240ab70&file=NXSolid.png
What are you modeling? It looks like a section of a tree-trunk. Like one of those tables made from a slice of a Cypress tree:
football-coffee-table-shaped-tablesfootball-tables-herringbone-rh-timber-pinterest-wood-for-top-search.jpg
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
You can not, as a general rule , create freeform objects with interior holes-s , in one step.
( There is to my knowledge one exception which is the Bounded plane feature. - not "freeform" but a surface.)
In this case you must create the outer and the inner as separate features and combine at a later stage.
in this case i would imagine that you should use the alignment by points, I imagine that the other methods will not do what you expect.
Tomas
Thanks Toost.
And John, it's a leg muscle, the hole is where the model of the bone will be incorporated. There are thousands of these cross sections for the whole leg, I only included two of them to get the idea across. Since there are so many I was looking towards automating the process, which is why I wanted to see if the operation could be simplified.
