ghamsa
Chemical
- May 21, 2003
- 70
We have a shell & tube heat exchanger which uses sea water for cooling the hot process stream.
we need to install a PSV (pressure relieve valve)on sea water cooling stream based on tube faluir case. The question is that where should we install the PSV (on inlet side or outlet side) of the sea water cooling stream and why? or it makes no difference either way.
Thanks for your usual support
