IsaacStructural
I have a four unit residential building with significant settling in one corner. I'm thinking reinforcing with helical piers or another similar system. I'm not concerned particularly with the load on an individual pier as the loads should be low when compared to the pier capacities. My concern with is spacing the piers. The foundation wall wasn't designed as a beam to span between the supports. I don't even have existing drawings to confirm if it is reinforced.
my instinct was to space the piers at no more than about 8 or 10feet and to take the piers to one spacing beyond the extent that I observed the settlement. Is this overly conservative? I've got a contractor who wants to use half as many piers, by reinforcing a smaller area and using wider spacing.
Licensed Structural Engineer and Licensed Professional Engineer (Illinois)
