polskadan
- Nov 8, 2011
- 21
Hi all,
I have a question regarding a local check that I need to perform for a spreader beam. For this given application the lifting points on the beam are directly over the loading points, so in theory this means no shear is in the member , rather there is tension flowing through the web of the beam (although I also do have compression as well as flexure due to the eccentricity of the lifting point and angle of lift). My question is what is the effective area that I should consider as resisting the tensile stress? In a column it is as simply as P/A but in this case my 'A' becomes a local issue and thus an effective area is needed. Does anyone know of a reference for this effective area? Right know I am leaning towards using b_effective as the length of the lug plate however would like to know if this stress distribution has been referenced before in literature. Thank you ahead of time for your help!
