SolidWorks developers agree that the Help file does indeed need some clarification. Here's basically what it should say:
BEAMS:
- You can apply loads to joints, reference points, or structural members (beam bodies).
- You can apply restraints to joints only. There are 6 degrees of freedom at each joint.
TRUSSES:
- You can apply loads and restraints only to joints. There are 3 degrees of freedom per joint.
Thank you again for reporting this.
SolidWorks has confirmed the problem and has assigned a SPR (Software Performance Report) with development to have this problem addressed. Please see the subject of this message for the SPR # for your reference.
You will be notified when this has been addressed. SPRs are addressed in Service Pack releases and annual major releases of the software.
You may also look up the status of this SPR via the SolidWorks Knowledge Base in the SolidWorks Customer Portal by searching for the SPR #.
Have a good day,
