cve60069
- May 1, 2010
- 84
Hello
I am having to design a thin (60mm) reinforced-concrete slab that will be supported on a grillage of one-way spanning beams (Picture) and I need to check the whole for a concentrated 100kN load in the centre of the slab. The concrete and steel are free of each other.
I am assuming that the slab will be able to spread the load across the joists and the maximum deflection will be beneath the point-load.
I need to check the stress and deflection in the concrete and steel and am not sure how to proceed. Any help in analysing a load sharing structure would be appreciated.
