Also, a static load is defined using voltage and VA, so if the actual voltage is lower than what was used in the loading tab then you'll see a lower VA for that load. From your numbers, the voltage drop at the load is likely about 3% assuming you did use 0.4kV for the load voltage on the loading tab.
