ecrmorri
- Aug 4, 2003
- 3
the grid has to be 1 square meter and 4cm deep. It is for a drainage sump. The grid spacing is therefore not critical. Could a grid this size ever support a 5 tonne Uniformly distributed load. The load it will bear will actually come from a forklift sitting on it ( worst case scenario is probably then a point load from one of the wheels acting at the centre). What kind of calculations would I need to perform. I have seen one manufacturer with a similar grid which states it will only be able to support a 0.5 tonne UDL. The grid is to sit over a hole with a 50mm wide recess.
Thx
ecrmorri
Thx
ecrmorri
