snapper3
- Apr 27, 2007
- 4
Greetings Cryo Experts! I'm new here and was hoping to get some information about a problem we're having with our LN2 pumping system.
First, here's some specs on our system:
Pump - DPD series footmount recip by Pittsburgh Cryo, 4000psi max, not sure of GPM
Tank - 1500 gal, 96" high, topped off weekly
Suction line - 1" from tank, 1-90 deg turn into pump, total length about 30"
Running time - about 30-40 minutes once every 2 hours
Vapor return line installed back to tank
We're pumping through an evaporator to supply N2 gas to our facility at 2500psi
Our problem is that the pump frequently loses prime and ceases to pump liquid into the evaporator. Our maintenance supervisor has discovered that we can regain prime and start pumping by spraying a garden hose continuously onto the suction line before the pump. We've purchased refurbished cold ends and warm ends and still have the problem. This garden hose trick works in any weather, winter and summer, below freezing to over 100 degF.
Questions - Why does the garden hose trick work? Is he heating or cooling the line?
What are the possible solutions to our problem?
Thanks for your help!
Paul
Paul
