living hinge model 1
sonewone
Bioengineer
Any body has tips on how to model a living hinge on a plastic part. I need to to be able to have a lid hinged to a housing. I should be able to have 2 cfgs lid closed & lid opened. I am referring to for the hinge dims. But unable to figure out on how go ahead creating the cfgs for open and close.
Any body has a model to share?
Why not use something like an angle dimension in a sketch with different values for the different configs?
- - -Updraft
Though my part is a plastic part. But just the hinge part is a flexible. It behaves more like a sheet metal (Bent & flat positions)
Talking more about the hinge profile. In the molded condition it basically a flat plastic (lines in sketch). In folded condition, it is curved plastic (Arc in sketch)
Even if I would create 2 different configurations, I would need to consider 2 separate features (one for flat & another for curved). I would prefer if there was a way to handle it using same sketch geometry.
Secondly, there is this Flex feature, but its not a precise way of representing.
I wonder if there was a way to have a combination of sheet metal & non-sheet metal SW-part.
In the 'flat' config, make the curved portion of the bend the maximum radius of 500m. That should make the effect of the curve negligible.
Or use a spline (instead of two lines and a curve) to create the hinge section. The spline can be forced to be 'straight'.
CBL,
Thats a nice approach. I will give it a try for sure.
