maybe it's me be paranoid, but something doesn't jive about this. may need to check to see if the slab can hold the thing up to begin with. cracking of the slab would essentially make a smaller supporting slab area. that's not to mention the forces exerted by crawling, turning, load handling, etc. and doesn't address "near-edge" conditions. also, it seems like it'd have to be one heck of a slab section to act "rigid".
besides, why wouldn't the contractor take care of doing this analysis and making sure they don't mess up the slab? if something goes bad, you're on the hook for it because it will always be your problem since you did such a swanky analysis...unless this is all just a classroom problem.
