PKT_BLK works great
PKT_BLK works great. Thank you. Below is a Google-translation (German-English) of the readme file to help you with installation instructions.
Thanks again - I changed 23400 points to blocks in an instant. Nice!!!
readme.txt:
Exchanging points against blocks
AutoCAD Release: R2000
(Presumably down-and upward-compatible)
Version: 1 / 1
Note: Freeware - Freeware - freeware
Start calling: pkt_blk
required files: pkt_blk.vlx (program)
pkt_blk.mnu (menu - tool box)
pkt_blk.mnl (Menu - charging instructions)
Restrictions:% (unknown)
Programs: CADlon - Lisp over night!
Holger Brischke
Expresstools 2 German Project
Tel: +49 (0) 681/989 06 84
mobile: +49 (0) 175/205 88 77
mailto:
kontakt@CADlon.de
Installation: all files in a copy Acad search path
Embed customize menu: Tools-> Menus ... (Menu)
or: _.menuload (in command line)
! Call
imm following dialog box:
[Search] - search pkt_blk.mnu
[Shop]
Now, should the tool box pkt_blk are available!
Program Description
With this tool you can exchange points for blocks. A dialog box following program options are set.
- Replace all points / points selected
- Selection of the points limit on certain layers? If Yes -> the layer can be selected from a list.
- Block that will be inserted in place of the points. Existing blocks are listed.
If you insert a block name that is not present in the drawing, a "standard" block is generated and inserted. This is an X with the line length of 5x5 drawing entity; whereas
Notes on suggestions and criticism, I would look forward to.
Holger Brischke
