LISP-routine 1
Hmo
42
I'm searching for a lisproutine that can do the following thing.
- It asks a string (for instance "N12.")
- It asks an incremental startnumber (for instance "1")
- It asks to select objects
- It places the string together with the incremental number in an attribute "KRING"
The result must be this:
Attribute1: Attribute2: Attribute3:
N12.1 N12.2 N12.3
The way the objects are selected is also the way the number are incremented and placed.
Can anyone help me for this problem?
regards
HMO
Dear Hmo,
The following code converts the text and dimension objects as you defined above. The code defines a new command "SNN".
(defun c:snn( / e elist n pstr )
(setq pstr (getstring "\n String: "))
(if (/= pstr "")
(setq pstr (strcat pstr "."))
(if (not (numberp *nncounter*))
(progn
(initget 1)
(setq *nncounter* (getint "\n Start from: "))
(progn
(princ "\n Start from <")
(princ (rtos *nncounter* 2 0))
(princ ">: ")
(setq n (getint))
(if (numberp n)
(setq *nncounter* n)
(while (setq e (entsel))
(command "._UNDO" "G")
(setq elist (entget (car e)))
(setq elist (subst (cons 1 (strcat pstr
(itoa *nncounter*)))
(assoc 1 elist) elist))
(entmod elist)
(command "._UNDO" "E")
(setq *nncounter* (1+ *nncounter*))
(princ)
Farzad
