liquid thermal expansion calc - help needed 1
heaterguy
I have density data that shows this liquid is 55.9 lb/ft3 at 200'F and 53.7 lb/ft3 at 300'F. What is the thermal expansion coefficient (beta)?
I have tried inverting the density adn calculating (0.0186-0.0179)/100 = 0.000007 but that number seems too small compared to similar fluids. What is the right way to do this?
TYIA,
Heater Guy
The equation for thermal expansion of any substance is given by
B = 1/V ( dV/ T)
where B = thermal expansion coefficient, V = Volume, dV = change in Volume, and T = change in temperature.
Your method looks right. Have you checked the units?
...because it should be [(0.0186-0.0179)/0.0179]/100 = 0.00039
beta = (dV/V0)/dT (PS: I am using d instead of delta and this is not a differentiation)
Dean,
It seems we have posted at the same time.
I hope heaterguy is now satisfied with the cubic thermal expansion value estimated by quark in 1/oF. When using oC the result should be multiplied by 1.8 .
Thank you. Your responses were sent to my spam. Sorry it took so long to reply. Quark answered my question.
heaterguy:
The information you provided is not enough to calculate the term BETTA. Unless, the pressure at the two conditions is the same.
In theory sailoday28 is right. The definition of the cubic thermal expansion [β], sometimes called alpha, is:
[β] = (1/V)([∂] V/[∂] T)P
However, the isothermal compressibility values
[κ] = -(1/V)([∂] V/[∂] P)T
are quite small when the liquids are well below their normal boiling points, usually lower than 2[×]10-4/atm, to sensibly affect the definition given by quark.
25362 (Chemical)
Can you explain in layman terms--How did you display the partials?
heaterguy
Knowing the liquid might give more of a handle on determining Betta.
To sailoday28. It's easy: via the Process TGML at the end of your message, look down for TGML Character Entity Reference. There you"ll find the answer to your query.
Another useful expression for [β] would be:
([Δ][ρ] /[Δ]t)(1/[ρ]ave)​
which in this case would result in:
[β] = [(55.9-53.7)/100][1/(55.9+53.7/2] = 0.0004/oF​
25362,
I was using either of the densities, but it makes more sense to use the average of the two. Thanks.
heaterguy
