Hi!
I’ve got an odd question and I’m not sure there is a definitive correct answer but I’d appreciate your postulations!
A customer uses a Liquid ring vacuum pump to create a vacuum in a vessel we supply.
Whilst carrying out a service on the vessel recently we were asked to inspect the pump as it was “noisy, and didn’t work well” (It did pull a vacuum but was incredibly noisy)
Even though it wasn’t our equipment, to placate the customer we examined the pump and found that:
a) the vacuum inlet (suction) line and water outlet (discharge)line we plumbed in reverse.
b) The pump was rotating in the wrong direction.
After a brief chat to the manufacturers to confirm our suspicions and we switched the pump direction and the mis-plumbed lines. Upon start up the pump now no longer pulled a decent vacuum, appeared to stutter and the motor got extremely hot to a point of smoking.
We undid our changes and tested the pump and it worked as prior to the changes.
The customer admits they’ve been using the pump in its current configuration on and off for six months, so my question is;
What is likely to have happened to the ‘backward’ operating pump during these six months that’s rendered it useless when set up correctly…and can it be fixed (I’m guessing that its probably terminal) but we'd like to advise the clients...
