MIkkelPoulsen
Hi
I working on making a simple liquid pipe head distributor design, where i'm pumping water from one tank to the top of next, and here i want to pump the water into a simple liquid distributor made of pipes with holes in.
But i do not know what speed i should calculate the hole in the pipes to - i do have some information on the water supply etc. but no experience on how to design the distributor pipe.
Any body has any experience in what speed is needed? It is not for spraying - just simple distribution over the complete area of the tank.
My values are this:
Tank diameter: ø1450mm
Water speed out of pump and into the distrubution pipe: max 3m/s (actual flow from below is: 1,3 to 2m/s) but the max allowed in the pipe system is the 3.
Pipe dimension inler: DN50
Water volume: 11-16mh3/h
Pressure: unknown at this time
How to design the nozzle pipe? I just want to make simple holes in a defined pipe size to make it simple
See picture here of the simple tanks:
And here in the top i would like to make a simple distributor like this :
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1681891618/tips/equipment_263695_cba54403edcb7317330b93ce8c40fd1ed20488fb_b5tet3.webp[/url]
Thanks in advance.
Best regards
Mikkel
My values are this:
Thanks in advance.
Best regards
Mikkel
