overkill4
- Oct 6, 2005
- 152
Hi All,
I have some cuts that I want to pattern and scale each instance a different factor, sort of a more elaborate area fill. My plan was to create the feature as a solid, pattern it, scale each body, then subtract the whole works. However when you use the linear pattern the feature is created as a single body.
Is there a better way to approach this? Or is there a way to separate the bodies in a pattern.
60% of the time, it works every time.
