Hello all,
This is both a code question as well as a technology question. Recently, I started doing some work for another of our offices where I noticed a fundamentally different approach to Fire Alarm System design.
This is for public schools, K-12 in California. We are required to install a fully automatic fire alarm system.
Many buildings will have dropped ceilings which will result in smoke detector coverage on the ceiling and heat detector coverage above the ceilings. Still basic stuff. Where I saw a difference is when I noted that this office was specifying the ceiling space heat detectors as "Linear Heat Detectors". These are lengths of multiple conductor cables of known resistance which initiate an alarm when temperatures exceed their temperature rating. Much of this is very similar to spot type detectors and the provisions of NFPA 72 are still referenced. For the system specified, " the installation seems to be a lot more complex and hence costly than using spot type detectors.
I am not sure we are using this in its intended application.
It seems that once the system goes into alarm the "sensor" is permanently damaged and must be replaced.
It seems a complex and first cost intensive system.
And appears to be a maintenance and servicing nightmare.
Does anyone have experience with these systems? Another manufacturer is "FARENHYT", (at least the manufacturer's used the same marketing/branding company-LAME NAME INC).
Do any of you AHJ types have any issues with these systems, especially the detector wire laying directly on top of the ceiling grid and tiles? Is this code compliant? There appears to be no codes directly speaking to linear heat detectors. This even according to the Installation Guide on the Protectowire site.
Look forward to any information available.
EEJaime
EEJaime
