L
ledo
Guest
I did a bit of research and if i am correct then this is true:
Proe uses file called Table.pnt for line pattern, line thickness, and line color definitions of the plotting output.
Or if we have a Postscript plotter then we can use the config.pro settings "Pen_X_line_weight 1-16".
And that is it? Or it does have options to set these with mouse clicking on the drawing?
What abaut this. Is it posible to somehow see the output of the drawing with all correct line types and weights and patterns before weuse Print and put the drawing on the paper?
Edited by: ledo
Edited by: ledo
