I have a new multi-fiber braided mooring line that is to be used for deep sea buoy moorings. I need to generate a function for axial stiffness (EA) in order to model this line in a computer program. We have a line tester and have generated Tension v. Strain curves, which are expectedly non-linear (5th order polynomials). From these functions we differentiate to get our EA.
There’s the back story, now my problem lies with the behavior of this line under a load. We load the line to 100 lbs and place our sensors on the line, then pull it up to 50% of its breaking strength(~3500 lbs.), then relax it to about 100 lbs again. From there we repeat this loading cycle multiple times. On every test after the initial pull we generate values for strain that are up to 30% less than those of the first pull. The lines length does not change (ie. we have not plastically deformed it and the initial length is roughly the same, within 1%); the line simply stretches less than it does on the first test. If brought back to a zero load and allowed to relax it will pull again identically to the first test. I'm having trouble figuring out what's going on here and was hoping someone might have seen this behavior before, or had an idea on what could be causing it.
