jonesey
- Oct 6, 2002
- 60
We have both 5Cr and 9Cr piping material specifications. ASME B16.48 (steel line blanks) only lists forged material for 5Cr, and no 9Cr material is listed. The forged material is listed i presume because forgings are less susceptible to laminations than plate material. What type of material should be chosen for 9Cr specs ? 9Cr forging, which is not listed in ASME B16.48 or should we go with 5Cr material which has less strength/corrosion resistance ?
Any input will be appreciated.
