PennStateIE
Industrial
Hi. I have a pretty basic question about line balancing. After time studies have been done at each station of current assembly line, you can calculate the allowable minutes and delay time for each station. When trying to balance the line, how do you take into account that you can add accumulation space between stations (in essence reducing or eliminating the delay time)? How do you show that? In other words, if the allowable minutes for the line is 1 and the normal time for a station is 0.5 minutes, then the delay time would show up as 0.5 minutes for that station. I can add accumulation in front of the line which I believe will allow the worker to continue working and not have delay time due to the worker in front of them. Do I just show the line as balanced at that point?
