Feb 12, 2010 #1 drafty2 Mechanical Joined Feb 12, 2010 Messages 2 Location AU Drawing a line in Inventor 2010 in sketch mode then dragging mouse to create an arc, used to work, but somehow has lost the plot! Is there a work around like a setting etc I may have altered.
Feb 13, 2010 #2 EngAddict Mechanical Joined Oct 1, 2009 Messages 410 Location US Draw a line, hover over the end until the dot goes grey, then click and drag. It should work even if you have constraint inference off. Maybe just check you have all service packs then. It should be working. Upvote 0 Downvote
Feb 15, 2010 #3 rollupswx Mechanical Joined Dec 31, 2007 Messages 918 Location US Make sure you have not turned off Coincident Constraints or fooled with Constraint Persistence. Upvote 0 Downvote
Feb 16, 2010 #4 EngAddict Mechanical Joined Oct 1, 2009 Messages 410 Location US "Make sure you have not turned off Coincident Constraints or fooled with Constraint Persistence." Constrain persistence is not required but you are right about coincident constraint, you must have it checked. RMB, constraint options. Upvote 0 Downvote
Feb 16, 2010 Thread starter #5 drafty2 Mechanical Joined Feb 12, 2010 Messages 2 Location AU Thanks guys, I had the constraints switched off for some reason? Upvote 0 Downvote
