Quoting vesselfab: "If I want to give my client good value for his big dollars invested in capital equipment, I would NEVER limit a vessels mawp by a nozzle neck or it's reinforcement. I would consider that very bad design on my part."
I respect your opinion, and I would agree that it is a common opinion, but I can't say that I agree that it has any reflection on the quality of the design. (It seems that this requirement is more common on the pressure vessel side of the industry, although we see it routinely on the S&T exchanger side as well.) As a mfg of shell and tube exchangers, this requirement is usually not a problem to meet...BUT, it does increase the cost of the exchanger, and can create excessive reinforcement, which can create fabrication challenges.
The notion that nozzle reinforcement is cheap, and thus should not limit the MAWP, is not always true. At times, I have seen situations where the pressure for nozzle reinforcement calculations had to be increased by a few hundred psi to meet this requirement--this can take you from a standard pipe nozzle neck to a custom bottleneck forging. I am not saying this is the usual solution, but I am trying to make the point that nozzle reinforcement is not always a "minor component". Even in more common, less drastic cases, where the usual solution is to add a reinforcement pad (which is sometimes an undesirable solution) or a long-weld neck, the increase can be costly, especially for larger diameter nozzles.
